It is currently Mon Jan 21, 2019 2:21 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Removing light
PostPosted: Sun Jan 17, 2016 11:53 pm
Whats your location?: Cork Lad!
What Minis have you?: 1995 Mini Sprite!
Owned a 1995 Mini Cooper!
Hi guys just looking for some help in how to remove the rear lights (the complete unit) does this involve removing the fuel tank? Also how do I remove the indicators?
Kev
 Post subject: Re: Removing light
PostPosted: Mon Jan 18, 2016 8:37 am
What Minis have you?: 1960 Morris Mini mk1
1969 Austin Mini mk2
1963 mini van project
142 Mini countryman
Ya you will have to take out the bolt for the fuel tank and slide it across. Then to remove the whole unit there is just four bolts to open inside the boot on each side.
IMOC Vice president 2018
PostPosted: Mon Jan 18, 2016 5:49 pm
Excellent thanks a million. Any idea about the side indicatorS? Also would anyone have a link to brakes i could move to when changing to 10 inch wheels?
PostPosted: Mon Jan 18, 2016 8:38 pm
Minispares do two kits for conversion,their own brand calipers
http://minispares.com/product/Classic/B ... 0to%20shop
or this kit with AP original spec calipers.I have used the Minispares calipers and find them good but each to their own.
PostPosted: Mon Jan 18, 2016 9:31 pm
I presume you mean the side indicators as the front ones are just screwed on.
With one hand under the arch pushing the indicator outward move the indicator with your other hand towards the front or rear of the car and it should come out without too much force. The wire and bulb holder simply twist out of the back of the lens.
PostPosted: Mon Jan 18, 2016 10:56 pm
Lads thanks a million much appreciated :mrgreen:
