It is currently Sat Jan 19, 2019 2:31 pm
Post new topic  Reply to topic  [ 2 posts ]
 Post subject: Gutter
PostPosted: Fri Mar 17, 2017 11:02 am
Whats your location?: Kildare
What Minis have you?: 1975 VTEC round nose
1976 Mini Clubman
Can anybody recommend a good product to seal the gutter before spraying
 Post subject: Re: Gutter
PostPosted: Sat Mar 18, 2017 11:47 pm
What Minis have you?: Clubman Estate
I ran a bead of PU (Polyurethane) Sealant around the gutter of my estate and spread it with my finger it over paints without issue and doesn't shrink or react to paint make sure you wear gloves (only comes off when your skin does if you let it dry) and a small bead is plenty and wipe off excess with some thinners as its tough to remove when dry if i was doing it again I would mask off either side of where you want it and just peel off masking tape before it dries for a really clean finish, its great for sealing internal seams and welds too spread it with a disposable paint brush with bristle cut short to work it into the welds / seams
