It is currently Sat Jan 19, 2019 3:00 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Mon Jul 03, 2017 10:01 pm
Whats your location?: Meath, Ireland
Hope someone on here could give me some advice on my Mini.
The car starts ok and drives ok, but when coming to a stop at say a traffic lights the idle starts to go up and down struggling to stay up and then can cut out. Doesn't happen all the time but starting to be a concern, easy to avoid by putting food on the gas, but would like to find a solution. I had it hooked up to a computer and nothing was showing so that didn't really help.
I been reading this could be a common problem with the fuel pump, but replacements look expensive and would like to narrow it down.
A friend said if it is the fuel pump I could get a fuel pump upgrade that fits into the pump which is cheaper, but I can't find this online to try.
Any help appreciated.
PostPosted: Tue Jul 04, 2017 9:59 am
When you had it hooked up to a computer was it a fault code reader or did it show live data of the engine running?
PostPosted: Sun Jul 09, 2017 3:16 pm
Think it was the fault code one has brought up a small thing which was eliminated.
PostPosted: Mon Jul 10, 2017 5:48 pm
Best to get a live readout if the fault code didn't cure it otherwise you spend money replacing parts you don't need.
