It is currently Fri Nov 03, 2017 6:04 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: engine help
PostPosted: Thu Jan 13, 2011 1:35 pm
Whats your location?: dublin
imoc member
as some of you may no i am a nightmare with engines in my mini (rings seem to go on 4 engines) so i took my engine out striped it down to the block just the crank rods and pistons left in it . now hear is the funny part i only checked the head yesterday and it turns out 1 of the valves needs to be re seated .i turned the head upside down and put petrol in to the head and the 2nd cylinder empty'd in 2 seconds so now my engine is striped down but other than the low compression on number 2 the engine was sweet and came apart really easy not a tap or click out of it ....so should i replace the rings anyway and the bearings or just hone it out and sort the head .i havent realy got the money to do the rings but if i have to i will .... the clutch is new along with the water pump and the cylinders are perfect i put oil down the cylinders a over a week ago and by the looks of it it was all stil there until i cleaned it out and filed with petrol that did go down but not in the first hour it must have went over night im stuck as to what to do next should i just clean everyting and refit ? also there is no weir on the cam or crank + rods and pistons look to be perfect
i no its kinda stupid 1 to ask but i just wana be sure
please dont reply saying that im tick for not checking the head as i already feel fairly stupid lol
thanks in advance
 Post subject: Re: engine help
PostPosted: Thu Jan 13, 2011 2:01 pm
When you look int the bores cleaned can you still see the cross hatch marks or are their virtical scratches??... you should realy only need to replace the rings if you see scratching, otherwise i'd say your's would be fine.....
PostPosted: Thu Jan 13, 2011 2:34 pm
imoc member
cross hatch markes still there like there looks to be no wear at all ..... im tinking the engine could have been rebuilt befor i got it the flywheel was really east to take off i got a flywheel puller for 30 euro and it poped off in 2 seconds and i no they normaly take a while but everyting looks perfect
PostPosted: Thu Jan 13, 2011 5:09 pm
Dont Even think of puting it back together with out changing the rings and honing the block its a no brainer IMO, a ring pack from minispars is 40 euros and a hone cost you nothing.
get the valves reseated professionally in the likes of Howard Engineering they only charge 50 euros and it will probably improve the motors power by 20% very worth wile
PostPosted: Thu Jan 13, 2011 5:41 pm
in that case are you sure your problem is the piston rings and not just the head??
PostPosted: Thu Jan 13, 2011 7:24 pm
imoc member
is there any1 in dublin that would sell the ring set standard size and gaskets and have them in stock illhave to get them monday ..... should i do the shells aswell even if thers no were on them......pistons are dished numbers on them are 20601 f46 1025 or 1D25 it was hard to tell ? i no ian in miniquip has bearings and gaskets on the shelf i had to get the piston number first
its defnitaly the head its just a valve i have som1 to do the head work
