It is currently Wed Jan 23, 2019 5:42 pm
Post new topic  Reply to topic  [ 1 post ]
 Post subject: 1275GT update
PostPosted: Sat Apr 22, 2006 10:21 pm
I have spent a bit of time going over the GT since I moved it.
The clutch problem (as per the last update) seems to be either with the slave cylinder, or the flexible pipe between the slave and master has collapsed internally and is not allowing the fluid back to the master cylinder. Does anyone know if you can get the flexible pipes in a regular motor factors or will I need to order it from a Mini specialist?
The petrol tank has started to leak. Anyone got a spare for sale? It would be handy if it was somewhere in south Dublin.
Other than that it needs a few panels/patches to be welded in, and the rear subframe to be replaced. More updates soon!
