It is currently Wed Jul 18, 2018 6:07 am
Post new topic  Reply to topic  [ 10 posts ]
 Post subject: SRS light
PostPosted: Thu Sep 18, 2014 4:52 pm
Whats your location?: Louth
What Minis have you?: 2002 Rover Mini
1998 Austin Mini
One of my minis has been layed up for a while and battery went dead. When i put new battery in the srs light is now on constantly. Is there anyway to get it to go off without having to pay someone to plug in the computer?
Any help would be greatly appreciated.
cheers,
Diarmuid
 Post subject: Re: SRS light
PostPosted: Thu Sep 18, 2014 5:05 pm
Sometimes if you clean the plugs on the seatbelt tensioners in the rear pockets can clear a fault.
PostPosted: Fri Sep 19, 2014 10:29 am
1998 Austin Mini
hmm, tryed that last night no success.thnks
ill have to plug it in. will any garage be able to sort it or do i need to go to a special one
cheers,
PostPosted: Sat Sep 20, 2014 11:35 am
Only some diagnostic readers will do the SRS system. Call james in Minifix he may have the reader. I know Ryans in Blanchardstown do it and you could try the old Rover garage in Dundalk.
PostPosted: Mon Sep 22, 2014 11:53 am
Mayo
I'd you check all the fuses first?
PostPosted: Mon Sep 22, 2014 2:29 pm
SRS is a stand alone system with its own loom feed from one fuse. If the lights on fuse should be ok.
PostPosted: Tue Sep 23, 2014 12:54 pm
1998 Austin Mini
Thanks so much for the guidance. Its really appreciated.
So i went into martins rover garage in dundalk. He has all equipment spi and mpi cars. We plugged it in and it wouldnt talk to the control unit. So I disconnected the battery pulled the bulb, put it back in and now for some reason the computer is now talking to the control unit and the light is going off and on as its meant to....
I dont know what i did but it worked..
hmmmmm :)
PostPosted: Wed Sep 24, 2014 11:58 am
Interesting .
I must start a technical thread " Tips for SRS system"
Did you put the bulb in before or after connecting the battery?
PostPosted: Sun Sep 28, 2014 3:37 pm
1998 Austin Mini
yes,
definitely would be useful to others.
I put the bulb in before reconnecting battery
1998 Austin Mini
yes,
