It is currently Tue Jul 17, 2018 3:55 pm
 Post subject: fiesta brake pipes
PostPosted: Wed Oct 15, 2014 11:04 am
Whats your location?: waterford
does anyone know anywhere I can get sum brake pipes made up. for my fiesta brake convention
thanks ed 8)
 Post subject: Re: fiesta brake pipes
PostPosted: Wed Oct 15, 2014 9:34 pm
What Minis have you?: 60 Austin Se7en
61 van,68 MKII,
I made my own with fittings from Merlin motorsport,UNF on the Mini side and metric on the fiesta side.
https://www.merlinmotorsport.co.uk/s/go ... e-fittings
PostPosted: Wed Oct 22, 2014 9:15 pm
Have you got a tap and die set? I done the fiesta caliper conversion and was left with the same dilemma, I decided to drill a hole and using a tap a thread the same size as the mini brake pipes... drilled a hole in the same spot as on the mini calipers and got a bolt and stuck it in the original threaded hole... hmmm don't know if that makes sense but go look at my clubby estate build in projects and you can see some pics there... what did you do for the flanges by the way? Find metro ones????
some day....
