It is currently Wed Jan 23, 2019 6:08 pm
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: engine won't start
PostPosted: Wed May 20, 2015 6:47 pm
Whats your location?: Cork Lad!
What Minis have you?: 1995 Mini Sprite!
Owned a 1995 Mini Cooper!
So my mini wouldn't start. It's just ticks. I had a bit of a battery problem but I got a new battery and the mini still won't start just ticks. But if I connect the mini to a battery pack the mini will start and run perfectly. Any suggestions on what the problem could be?
 Post subject: Re: engine won't start
PostPosted: Wed May 20, 2015 8:59 pm
PROJECT X
Is it the solenoid that is clicking ?
Could be starter motor, something as simple as brushes in the motor sticking.
PostPosted: Wed May 20, 2015 11:45 pm
make sure your solenoid is earthed properly
PostPosted: Mon May 25, 2015 12:09 am
Nice one lads that did the trick
