It is currently Sat Oct 20, 2018 7:17 am
PostPosted: Fri Apr 01, 2016 11:39 pm
Whats your location?: Knocknagoshel, North Kerry
What Minis have you?: 1983 Mini
Well! So heres the story.. 1275cc engine.. sat outside a long while.. got it on the chaep.. head gasket gone.. full of water.. slight surface rust in the cylinders... Rebuild!
So what i want to know is since there is surface rust on the cylinder will i have to bore it out?.. or would just cleaning it do the job? if i was going to bore it out can you buy 1293 cc pistons?.. I checked and you can only buy kind of half a 1293 engine itself which costs a fortune...
Any ideas??
Very much appreciated! Dont have much experience building engines so any advice atall is great!
Mini Mad!
PostPosted: Sat Apr 02, 2016 9:48 pm
Would suggest u bring the block to a machine shop that does engine re bores / hones for their advice ( whether a clean up or re bore ) .
Yes you can buy 1293 pistons as a set . Mini spares part no P2151-20 or 2153-20 .
DOUGAL
PostPosted: Sun Apr 03, 2016 10:51 pm
Thanks a million Dougal! Much appreciated!
Mini Mad!
