It is currently Tue Oct 23, 2018 6:31 am
Post new topic  Reply to topic  [ 2 posts ]
 Post subject: MPi ECU
PostPosted: Sun Nov 13, 2016 3:35 pm
how to reset your ECU (MPi) if you replace a sensor.
1] turn ignition on - engine *not* running
2] press accelerator all the way to the floor 10 times
3] turn off ignition
http://www.uscars.biz/uscars/mini-documents/Mini_MPI_Reinitialisation_ECU.pdf
 Post subject: Re: MPi ECU
PostPosted: Sun Nov 20, 2016 9:59 pm
I'm in the middle of replacing the cooling system, sensor included.
I wasn't aware the ECU needed resetting. Thanks for posting!
MINI
...where size doesn't matter!
