It is currently Fri Jan 19, 2018 7:20 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Mon Apr 24, 2017 11:14 pm
Whats your location?: Ballinascarthy, Co. Cork.
What Minis have you?: 1994 Mini 35 Nevada Red.
Modifications: None so far.
Hi I have just purchased a 1994 mini 35. It has two issues. A hunting idle and running on when ignition is switched off. Any ideas where I should start?
PostPosted: Tue Apr 25, 2017 1:51 pm
First and easiest thing to check is timing , checked with a timming light with vacumn pipe disconnected to make sure its not too advanced.Also check condition of vacumn pipe. Could have an air leak around carb
PostPosted: Tue Apr 25, 2017 3:58 pm
Your car should have three vacuum pipes and a vacuum stat which opens when the engine is warm. The vacuum pipe runs from the carb to the stat and than from the stat to the dizzy with a T off to the charcoal filter under the wing. You should disconnect the one onto the dizzy when checking timing.The stat is located on the thermostat housing and often one of the hose connections is broken.
PostPosted: Tue Apr 25, 2017 7:03 pm
Thank you for the reply. I with give that a go. I did pull a spark plug this morning and its white. That's a lean mixture right?
PostPosted: Tue Apr 25, 2017 10:35 pm
So the connector of the vacuum pipe is broken at the dizzy side. Where can I get a replacement.
PostPosted: Wed Apr 26, 2017 1:41 pm
http://www.minispares.com/product/Class ... o%20search
Minispares
