http://www.irishminis.ie/forum/
Removing the Cat on a 1994 Carb Mini
http://www.irishminis.ie/forum/viewtopic.php?f=13&t=11296
Author:  Jknight [ Tue Sep 26, 2017 4:43 pm ]
Post subject:  Removing the Cat on a 1994 Carb Mini
Just wondering if this would cause problems with the emissions for the nct?
Author:  woody [ Tue Sep 26, 2017 6:54 pm ]
Post subject:  Re: Removing the Cat on a 1994 Carb Mini
special case for carb minis with cat ,see page 13 note 3.
https://www.ncts.ie/media/1004/nct-manual-july-2014.pdf
Author:  Jknight [ Wed Sep 27, 2017 6:55 am ]
So would that mean without the cat the car will likely fail?
Author:  woody [ Wed Sep 27, 2017 9:49 am ]
I know of at least one that passes without the cat.
Author:  davem [ Wed Sep 27, 2017 8:53 pm ]
If it's not mine, then there's at least 2! :D
1994 1275 Sprite with a stage 1 kit on a HIF38
Author:  Jknight [ Thu Sep 28, 2017 12:50 pm ]
That's exactly why I'm asking. Thinking of fitting the same to my car. Did the stage one kit make much of a difference?
Author:  woody [ Thu Sep 28, 2017 6:05 pm ]
The one I know has a LCB and Maniflow exhaust with a HIF44 with a BDL needle and standard air filter. Standard engine and dizzy.
Author:  davem [ Wed Oct 04, 2017 9:22 pm ]
To be honest I have no idea! Never had a mini before and this wasn't running when I got it, as part of restoring it I put the stage 1 in. So I've nothing to compare to.
Page 1 of 1 All times are UTC+01:00
https://www.phpbb.com/
