It is currently Sun Jul 22, 2018 7:10 pm
 Post subject: Petrol/Engine Issue
PostPosted: Fri Sep 29, 2017 9:22 am
Hi all,
Having a strange issue. I hadnt driven the car in a few weeks, and the clutch was dead. I managed to bleed the clutch and all working fine.
However, the car has been running rough. Ive noticed I am going through a serious amount of petrol the last week, and the car had cut out twice coming off the motorway. Once, I could restart it, I had to get the car jumped. However, it has had no problems since then, with the car starting fine each time. The second time it cut out, I was able to start, after pulling the choke out. I had to leave the choke out for the remaining 5 minutes of the journey.
Both times, the car had been running for nearly an hour, and have a combination of start stop traffic and motorway runs.
Any suggestions what this could be?
I was thinking fuel filter/pump at first, as using more petrol and it cutting out. But then was thinking alternator, as the battery died and needed a jump
 Post subject: Re: Petrol/Engine Issue
PostPosted: Sun Oct 01, 2017 8:38 pm
Do you have a stand alone fuel pressure regulator fitted?
I had similar problems years ago with one of them, changed to a filter King and no more problems
PostPosted: Mon Oct 02, 2017 9:24 am
If your using more petrol than normal than baring a leak it is most likely the carb. A blocked filter , weak pump or electrical fault will not use more petrol. Strip and clean the carb.
