It is currently Sun Apr 22, 2018 7:36 am
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Thu May 07, 2015 5:50 pm
What Minis have you?: 60 Austin Se7en
61 van,68 MKII,
With just over a week until we head off from the Viaduct Inn for MTM 2015 now is a good time to the final preparations if you have not done so already.
All participants are reminded to ensure that their car is in roadworthy condition and in good mechanical order so as to cover the 450 aprox miles from Mizen Head to Malin Head.Wheel bearings,ball joints,fan belts,cooling system,drive shafts,brakes,lights and all other systems on your Mini should be checked over and any faults rectified before you set off. The recovery crew will maintain a steady pace behind the last Mini but should you deviate from the route or spend an inordinate amount of time sightseeing, you may be left behind and the recovery crew may not be able to help you should you need assistance.And remember that it is a RECOVERY service and not a breakdown service so if you are unfortunate enough to suffer a breakdown they will endeavour to get you on your way but any large scale mechanical problems will leave them no other choice than to load up your Mini and leave it to a safe place.Proper preparation of your Mini now should help to ensure you complete the event without a hitch and will also enable you to have a better experience without the stress of breakdowns.Also as this event is being held on public roads it is up to each entrant to ensure that their Mini is in full compliance with the rules of the road and has proper insurance cover,tax and nct where applicable.
Below is a list of suggested items to bring with you:
1. A fully inflated spare tyre,a can of tyre weld, a jack and wheel brace.
2. Oil, Brake Fluid,a small jerry can of petrol & Water/Coolant;
3. A set of spanners. 7/16", 1/2", 9/16" will cover most things (11mm, 12mm, 13mm, 14mm if you're stuck)
4. A fan belt, head gasket and a set of points (make sure they are the right ones for your Mini)
5. A coil and a condenser(make sure they are the right ones for your Mini)
6. A bottle of good rad sealer.
7. A mobile phone/charger and a warning triangle.
8. Enough cash to pay for your accommodation, petrol, food, and drink!
9.A Sat Nav for use with the tulip diagrams.
10.A head gasket
11.A tow rope
I will post a timetable of the weekend tomorrow and emails and snail mail will be sent with final details of MTM 2015 tomorrow.
PostPosted: Thu May 07, 2015 9:43 pm
61 van,68 MKII,
The top ten breakdowns listed by the AA are
1. Flat or faulty battery
2. Flat or damaged tyres and wheels
3. Keys and immobiliser
4. Alternator faults
5. Ignition problems
6. Fuel
7. Starter motor
8. Cooling system
9. Clutch problems
10. Cambelt.
While some of these are not applicable to Minis,most are and it gives an indication of common problems so if you give all these items the once over and make sure your Mini is hail and hearty come the morning of the 16th then chances are that you will have a breakdown free MTM.
