It is currently Tue Jan 22, 2019 2:40 am
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: Gears
PostPosted: Mon Sep 15, 2014 1:06 pm
Whats your location?: Louth
What Minis have you?: 2002 Rover Mini
1998 Austin Mini
Hi
Have recently purchased a 1998 austin mini cooper. When ever im changing down from 3rd to 2nd there grinding. It doesnt happen on any of the others and only when going down.
Anybody able to help with an idea on whats wrong?
cheers,
diarmuid
 Post subject: Re: Gears
PostPosted: Mon Sep 15, 2014 2:45 pm
Balk ring on 2nd gear has worn out, very common problem , Ive just done my '96 Equinox . Although the balk ring itself isn't expensive the labour involved is. Engine out ,remove gearbox, dismantal total gearbox then put it all back together. Proberbly the biggest job on a mini.
PostPosted: Mon Sep 15, 2014 3:01 pm
1998 Austin Mini
Cheers woody,
probz a job for next winter, once i have a little more experience
PostPosted: Mon Sep 15, 2014 9:04 pm
Forgot to mention since its an MPi unless it has been done alredy upgrade the diff to a 4 pin diff.
