It is currently Wed Jan 23, 2019 9:39 am
Post new topic  Reply to topic  [ 152 posts ]  Go to page Previous 1 2 3 4 5 6 7 Next
 Post subject: Re: 1275GTi conversion
PostPosted: Tue Mar 15, 2011 8:01 pm
Whats your location?: Sandyford, Dublin
What Minis have you?: Matte black Leyland Mini Clubman 1380cc.
This looks like a savage mini!! Hope it all goes well for you!! And all that dedication will pay off for you!!
Hope to see it out and about!!
Don't under-estimate the mini!
PostPosted: Tue Mar 15, 2011 8:06 pm
KMG is internet-less at the moment but hopefully has been working away in the garage. There should be loads of progress to report on soon.
PostPosted: Tue Mar 15, 2011 11:07 pm
Billy wrote:
KMG is internet-less at the moment but hopefully has been working away in the garage. There should be loads of progress to report on soon.Billy
could that be described as InterNought?
PostPosted: Thu Apr 28, 2011 6:26 am
What with other things on the go it has been a while since I updated progress withn the GT.I had to sort out the exhaust and I am using a maniflow system so I needed to join the Suzuki outlet to the Maniflow.I got the long pipe from the Suzuki which started out looking like this.
By putting the Maniflow in place and offering up the link pipe I reckoned I needed the back part of the pipe so I cut that off
And I was left with this bit
I also needed the flange from the other bit so I cut that off and I had to file out the old piece of pipe from the inside of the flange.You can see in this photo the old pipe is still inside the flange.
I had to widen the Maniflow pipe to get the link pipe into it so I cut a couple of short slots to cut the link pipe to fit in.
Once I was happy with the way it fitted underneath the car and was well clear of the gear linkage I welded it up.
Because the link pipe was originally flared at the flange I needed to enlarge it to fill in the gap so again I cut lots of slots at the end and flared it out and with the exhaust in position I tacked the flange in place,removed it from the car and welded it up.
Here is the finished item
And I decided to give it a coat of green Hammerite to match the back box section.
PostPosted: Thu Apr 28, 2011 6:37 am
I have also been working on getting the MAF sensor mounted.I originally wanted to position it near the front of the car to cut down on induction noise but I have decided to mount it up near the bulkhead until I get the car running.I took a K&N filter I had for a HIF44 and cut the back to fit the MAF.
I then got some cork gasket and marked out a gasket for the sensor.
Here is the sensor with the air filter on.
And here is where it will sit in the engine bay for the time being.
I also welded plates over the brake hose holders on the subframe and drilled out smaller hoses as I will be making my own Aeroquip hoses.
I will be sending the subframe out for powder coating this week.
PostPosted: Thu Apr 28, 2011 8:45 am
kerryminigringo wrote:
What with other things on the go it has been a while since I updated progress withn the GT.I had to sort out the exhaust and I am using a maniflow system so I needed to join the Suzuki outlet to the Maniflow.....
thats going to be nice 'n loud!
PostPosted: Thu Apr 28, 2011 9:15 am
Very nice work Aidan, i have the same problem with the exhaust manifold, but i was looking last night, u can buy a pipe expander for 26 euro, it allows the u to expand one pipe to let the other side into it, seems to be a neat job
PostPosted: Thu Apr 28, 2011 9:55 pm
This is what the subframe and engine brackets looked like Monday evening.
And this is what I collected from the powder coaters today.
I blanked off the tower bolt threads with a couple of old bolts and washers.
And when I removed them I had nice clean threads.
I ran a tap through the holes for the top arm holding plate and I may have to run a round file around the top arm holes to remove the powder coating but after that it is ready for brake lines and fitting.
PostPosted: Thu Apr 28, 2011 10:17 pm
great work as always, that subframe looks great
PostPosted: Thu Apr 28, 2011 11:40 pm
thats a nice lookin inlet manifold :wink: :wink:
PostPosted: Mon Aug 08, 2011 9:18 pm
I suppose through lack of motivation I have not done much to the GTi lately but I have been doing little bits and pieces and now seeing as Maxi has his on the road I better get a move on.I had made a template for the inner wing to allow the alternator access and I marked up the inner wing.
Using a combination of jigsaw and nibbler I cut out the hole in the inner wing to allow the alternator through.I have a plan as to how to make up the cover so I will get working on that in the next couple of days.
I started work on the front brake hoses and I used Aeroquip hoses forall the front hoses.I had welded tabs onto the subframe for the one that goes to the passenger side and I also used pipe clamps to fix the fuel pipes in place.
I used a T-piece to connect the front pipes together and used more pipe clamps to tidy things up at the drivers side of the engine compartment.
I used bulkhead fittings to get the pipes into the pedal box.
PostPosted: Mon Aug 08, 2011 9:39 pm
I got in contact with John Staunton of JOMO engineering and he said he would get the drive shafts sorted for me.I gave him the measurements and he cut the shafts to lenght allowing for the joint.He took one side down on the lathe and put a hole in the other piece of the shaft.As is was designed to be an interference fit he had to use a combination of heat and a press to force the two pieces together.Then were then TIG welded to allow for twisting and the weld was cleaned up after on the lathe.I forgot to take pictures before I primed them but here they are.
As I have a great big pedal box in the way I cannot get fresh air to the heater at that side so I have to bring it in the other side so I took one early heater(because I want both pipes at the passenger side) and dismantled it.
A crude but effective way of testing the heater matrix with a lenght of hose,a bolt a couple of jubilee clips and an air gun.
I drilled out the spot welds holding the air intake at the drivers side.
And I mounted the motor in its place and tacked the intake to where the motor used to be.New foam on the inside and a lick of paint and it is ready for fitting.Not sure how effective the fan will be but I suppose I will find out.
I also ran the hoses to the pedal box from the bulkhead fittings.I need to make a bracket to mount the reservoirs in the engine compartment.
I finished the wiring of the toggle switches and it took 3 relays to do what the hazard switch normally does although one of those is just for the LED.Woody had a way of doing it using a switch only but this was not available in toggle form.
At present the engine if fitted and connected to the rad and exhaust and I will be fitting the suspension and moving towards getting the ECU connected.
PostPosted: Tue Aug 09, 2011 10:55 am
:) nice work.....
PostPosted: Tue Aug 09, 2011 12:48 pm
GO GO GO!!!!!!! :lol: Epic work, can't wait to see this car! :D
PostPosted: Tue Aug 09, 2011 1:19 pm
Beautiful work KMG. The car will be a real credit to you when it's on the road. All the best with the rest of it. :)
PostPosted: Fri Aug 12, 2011 7:20 am
As always very nice work Mr pres :D
PostPosted: Fri Sep 09, 2011 10:12 pm
Alternator mounted and wired up.
I needed to make an enclosure for the alternator so I got a piece of aluminium wire and bent in into the shape of the opening of the inner wing.I used it to mark out a piece of sheet steel which I would use for the lid of the box and then I welded a strip of metal around the top to form the box.I then used the aluminium template to mark out the contour of the enclosure and I welded a strip arounf the base and welded a couple of threaded section onto it so that I could bolt it onto the inner wing.
Aluminium wire template.
Top of enclosure cut out.
Top with side welded on.
Finished item awaiting cleanup and paint.
Suspension on and brakes plumbed.
I needed a way to join the battery cable along with the stater feed,alternator charge cable and fuse box supply cable so I mounted a busbar insulator on the cross member and ran all the calbe to that point.It will make it handy if I have to jump start it as I will have a boot board fitted.
I have the rad hoses connected but I will look into getting custom ones made after I get it running so that I can get rid of all the jubilee clips.I also mounted the expansion tank on the inner wing,this came from a 98 Honda Accord.
PostPosted: Fri Sep 09, 2011 11:57 pm
really nice work there... . its coming along very well.
PostPosted: Sun Sep 11, 2011 9:28 am
MTM2012....no pressure!! :wink: :wink:
PostPosted: Sun Sep 11, 2011 8:05 pm
great stuff aidan, really cant wait till you have it on the road so we can compare notes :)
presently im 75% deaf and have a fuel bill bigger than the 'northwestern'. but im told this
is just part of the running in process.
PostPosted: Mon Sep 12, 2011 5:32 pm
Would that be a safety issue there in the event of a short? With its proximity to the fuel lines?
PostPosted: Tue Sep 13, 2011 5:03 pm
All the terminals where covered with heat shrink and when the build is finished I will be putting thread-lock on the connecting bolt.I will also be making a cover to protect against accidental shorts and anyway when I put a right hand tank in it there will be 5.5 gallons of fuel basically sitting over the battery so if I was to worry about shorts it is there that I would be worried about. :D And the photo does not show that the insulator is about 60mm further out from the fuel lines.
PostPosted: Tue Sep 13, 2011 8:43 pm
Whats your location?: Maynooth
What Minis have you?: 1962 - Morris Traveller MK1 - 1978 - 1275GT, 1998 - Sportspack
Aidan,
why don't you use duck tape?
You would have had the car on the road by now.
PostPosted: Tue Sep 13, 2011 10:56 pm
zakgt wrote:
Aidan,
yea Aidan, dont'cha know it would be quacker?
PostPosted: Wed Sep 14, 2011 2:12 pm
Ah right! Id still be fairly worried about that in the event of a crash, are you using a inertia switch too? How did you mount the return line? Is it returning into the R/H tank and the supply coming from the L/H? You going to use a swirl pot design and two pumps or just the single pump?
