It is currently Wed Jan 16, 2019 4:44 pm
Post new topic  Reply to topic  [ 13 posts ]
 Post subject: Project Auto
PostPosted: Sun Sep 08, 2013 5:52 pm
Whats your location?: cork
What Minis have you?: 1975 saloon MG Metro powered
Modifications: MG Metro Goodness
Hi all,
Over the next few weeks I will be putting together a thread based on my auto mini
which took a year to do and on a budget......
So about a year ago I went looking for a 70s mini and found one on this site
I collected it in wexford and drove it home to cork
and got out of the car pain in my back :P
So here it is back at the house
oh no a oversill fitted :evil:
aahhh!!! rust
Dam oversill
So after I cut out the rust on the drivers side I made a half floor panel out of a sheet of steel
Here it is welded in place
Stay tuned for more ,
Thanks for looking Dave
 Post subject: Re: Project Auto
PostPosted: Mon Sep 09, 2013 8:24 pm
Hi all,
some more photos this is the front floor before and after
After that I moved to the rear pocket and rear subframe mounting panel, before welding this in I checked the mounts with the subframe
all was ok
Some one in the past tried a repair
New panel in
Then time for a full length door step
Please feel free to leave any comments
Thanks Dave
PostPosted: Mon Sep 09, 2013 8:28 pm
Fair play Dave, you're getting stuck in.
PostPosted: Mon Sep 09, 2013 9:50 pm
Handy with the welder too.
PostPosted: Wed Sep 11, 2013 7:18 pm
Hi peoples,
Thanks for the replys
I think its time for more work :idea:
So to finish off the drivers side I cut out the rust and cut and welded
in a new front panel I will leave the photos do the talking
Thanks for looking any comments welcome
PostPosted: Mon Sep 16, 2013 10:14 pm
Hi Guys time for more photos
On to the boot floor and I cut a bit of a hole
More rust in behind the paint have to sort this a well
I then fitted a boot floor panel which was a crap fit, sorry now for not going for a half boot floor :roll:
Here is some more rot on the other side
So I fabricated a new panel and here it is welded in
Thanks for looking
Dave
PostPosted: Thu Sep 19, 2013 9:32 pm
Hi all,
Time for more welding fun
I decided to go at the passenger side ,I made my own inner sill and jacking point
and then a door step , outer sill.
I will let the photos do the talking...
Oh no another hole
sorted
Thanks for looking
Dave
PostPosted: Sat Sep 28, 2013 9:20 pm
Hi All
more work to do , Time for a A panel on the drivers side and also lining up the door with it.
I had two doors skinned already from another project car
On to the passengers side and a new A panel also this side, and a passenger wing
The wing that was on it was put on by what looked like brazing......
Then it was onto the passenger side subframe mount
As with the other side it was plated in the past to hide rot
So I cut it out and also had to take a piece of the floor , here is a new section welded in
That's it for now peoples
please feel free to leave a comment
Dave
PostPosted: Sat Sep 28, 2013 10:49 pm
Keep up the good work!
PostPosted: Sun Sep 29, 2013 9:11 pm
Quality welding there, it can't of all been done by that Clark 130 hobby mig can it? My hat is doffed if it was.
PostPosted: Mon Sep 30, 2013 8:08 pm
Thanks for the replys Dave and Dylan yes it is a Clarke 130EN welder which is an excellent welder
when set up right > I have it now 3 years and never gave any problems :D
PostPosted: Mon Sep 30, 2013 8:24 pm
Hi peoples some more work done
From looking at different types of minis out there I am a big fan of de bumpered minis
so I decided to go for it with this car
The front was easy to do just drill out the front lip which in this case was in a bad way
Here it is off ready for weld up the holes
So a few hours later here is the front end , I also had a bit of work to do to the front lip of the bonnet
you can see the lip welded in
Thanks for looking please feel free to leave any comments
Dave
PostPosted: Tue Oct 29, 2013 7:09 pm
Hi peoples
time to finish up the welding...
I noticed a bit of rot on the corner of the roof
Some time to cut out
and a bit of welding and all is fine :P
A lick of paint and all should be fine
Thanks for looking
Dave
