It is currently Sat Feb 23, 2019 12:01 pm
Post new topic  Reply to topic  [ 16 posts ]
 Post subject: My new build
PostPosted: Wed Dec 20, 2017 7:53 pm
After 11 years of having my mini I decided to start build a nother one since Iv a spare shell. If a few mad idea's for it all will be revealed in time.
So this is the way I got the car
The 1275 lump out. Not using it for this build tho
Iv started the welding on it boot floor repair fitted
 Post subject: Re: My new build
PostPosted: Thu Dec 28, 2017 4:42 pm
Small bit of progress today got it up on the spit inner and outer sill and door step cut out and ready for new panels
PostPosted: Fri Dec 29, 2017 10:06 am
Those images aren't working I'm afraid!
PostPosted: Fri Dec 29, 2017 2:29 pm
You can now load pictures directly to your post using the upload attachment section just below the "Submit" button.
PostPosted: Fri Dec 29, 2017 2:58 pm
Thanks woody but it's saying file is to large even with one pic
PostPosted: Sat Dec 30, 2017 10:59 am
PROJECT X
Try using www.postimage.org , same as photobucket used to be.
PostPosted: Sat Dec 30, 2017 3:40 pm
Got it sorted thanks
Big news today the doner car has landed 1.3 non turbo starlet allways wanted to do a conversion so I said I'd give it a go 8) :D
PostPosted: Sat Dec 30, 2017 4:35 pm
Is that the 1331cc twin cam fuel injected.
5 speed box I presume.
About 88 bhp.
If it all works out I'm sure it wouldn't be too hard to move on to the turbo version.(130 bhp).
There is a limit on the size of attachments but the quality is still good enough if you resize them. I usually open them in paint, crop the picture and save as a jpeg.
PostPosted: Sat Dec 30, 2017 6:05 pm
Ya that's the one if I can find a 6 speed box from a g6 corolla mite go with that didn't want to go turbo straight away there's a 5efe 1.5 Toyota engine non turbo same size will fit straight in if one comes up cheep after time I'd go with it there 115bhp standard
PostPosted: Tue Jan 16, 2018 10:31 pm
Some more work done inner sill fitted
Wing taken off small patch put in over the shock mount and over the air vent
Drivers wing taken off to get started on that side
Going treating all the under side of the car with this and inside the sills wings and as much as I can was told by lots of people that it was very good so there's only one way to find out
PostPosted: Wed Jan 17, 2018 9:26 am
Good man Geoffrey,
I had a '99 1.3 Starlet a few years ago and it's a lively car with a sweet gearbox.
Keep the updates coming,
PostPosted: Thu Jan 18, 2018 2:35 pm
If you can find a jap import 4efe engine and its ecu they are 100bhp. Look for pink fuel injectors. 1500's are hard got nowadays. 6spd Corolla box has a name for being soft, I'd stick with standard 5 spd. Starlet GT turbo box, alloy end cover and 8 bolt diff, has a longer 1st gear and can also take Torsen type lsd out of 6spd Levin gearbox.
Looking forward to the build !
PostPosted: Sun Jan 21, 2018 3:43 pm
More progress got a corolla inlet manifold. Engine out of the starlet the the under side primed
PostPosted: Sun Feb 04, 2018 9:07 pm
More updates had problems with photos but think I got them sorted all the welding is done on the back end passenger sill and door step is in
Made the jig of the subframe and cut the subframe and started the fitting up
PostPosted: Mon Feb 05, 2018 9:03 am
PROJECT X
I've edited your post there Geoffory.
When posting photos from Postimage.org use the "Direct Link" address and the "Img" option on the forums Post a Reply box . This gives full size photos in your reply rather than a redirect thumbnail link to the host website.
PostPosted: Mon Feb 05, 2018 1:20 pm
Thanks Neil
Users browsing this forum: Google [Bot] and 3 guests
