It is currently Tue Feb 19, 2019 4:46 pm
 Post subject: Changing side bulbs
PostPosted: Thu Sep 07, 2017 7:09 pm
Hi all,
Silly question. How do you change the side bulb on a Clubman?
I've taken the light assembly apart and the bulb is in the headlight but seems like it's wedged in via a rubber base.
I assume there's an easy Nack to this, but having never changed one, just can't figure it out!
 Post subject: Re: Changing side bulbs
PostPosted: Fri Sep 08, 2017 2:25 pm
On a roundnose mini the side light is a part of the head light. On a sealed beam it hangs below the main lamp connector and on a halogen conversion it is a push fit into a rubber gromet on the back of the headlamp.
On a Clubman the sidelight is part of the indicator unit . remove the two screws that hold the lens on to reviel the sidelight and indicator bulbs.
You may want to put up a picture of what you have.
PostPosted: Fri Sep 08, 2017 7:40 pm
It appears to be a push fit. There is the main beams bulb above it, and then the sidelight in rubber grommet. Does this twist out or how does it come out? Don't want to wreck it.
I have roundnose lights on a clubby, and the indicator unit is just the indicator
PostPosted: Fri Sep 08, 2017 8:05 pm
Should just pull out , not too tight
PostPosted: Fri Sep 08, 2017 9:27 pm
Thanks. I'll give it another go. The rubber just looks too wide on the inside of the light to fit back out
