It is currently Fri Nov 03, 2017 6:29 pm
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: Doors
PostPosted: Wed Nov 18, 2009 9:20 pm
If I was to get my hands on a set of MK1 doors would they straight onto Stud or would they need modification?
Thanks in advance.
 Post subject: Re: Doors
PostPosted: Wed Nov 18, 2009 9:24 pm
Whats your location?: Cavan
What Minis have you?: 1966 850,92 city,98 2.5turbo R33 Nissan Skyline and a 1979 Mini Clubman
Modifications: To many to list!
Why do you want to do that?
Bending the rules,and ruling the bends,Since 1959!
PostPosted: Wed Nov 18, 2009 9:30 pm
co. longford
Mods with the hinges aneway.. :P
whats up with your own doors???? :lol:
PostPosted: Wed Nov 18, 2009 9:31 pm
There is nothing wrong with my doors, it's just as a matter of interest. :D
PostPosted: Wed Nov 18, 2009 9:33 pm
co. longford
oh rite..well by the time uve ur old doors modified il surely be drivin my mini :lol:
PostPosted: Wed Nov 18, 2009 9:34 pm
Would it not be as straight forward as drilling holes in your old doors and A panels and using mark 1 hinges?
PostPosted: Wed Nov 18, 2009 9:36 pm
Thats hat I was thinking but I did not know if the actual doors were the same size.
PostPosted: Wed Nov 18, 2009 9:38 pm
Yeah it should work if you can get the hinges bolted up on the inside of the door!
PostPosted: Wed Nov 18, 2009 9:40 pm
co. longford
But would you be after the sliding windows and differnt inside aswell??
PostPosted: Wed Nov 18, 2009 9:53 pm
Nope the two doors are totally different the MkI a Panel is different with stiffeners to hang the door on. The inner A and B post is different, also the door step is a different shape,
the windows and door lock Mechanism is different as well.
your seats will not work with MkI doors with out modification.
I is entirely possible to modify all these things but not with out needing to do some Painting paint.
It is also not possible to fit MkI hinges to an otherwise standard Mk III door with out considerably modifying to the inside.
PostPosted: Wed Nov 18, 2009 10:17 pm
Thanks Paul.
