It is currently Fri Nov 03, 2017 6:23 pm
Post new topic  Reply to topic  [ 23 posts ]
 Post subject: And three days later! :(
PostPosted: Sat Dec 26, 2009 11:54 am
Was giving a few lifts there last night just for friends as they were all out on the beer. I think it was about 4am I got home. I parked Stud in his usual space outside the home. About an hour ago I got up to get a gaskit of ClubmanGT, stepped into Stud and he wouldn't start :( He just turns over like the fuel cut off switch is set but its not. :( I'v cleaned the spark leads, checked the distributor, tryed to jump start it and just made sure everything was conneted. Any ideas anyone? I would love it to be running by tonight as if I miss the run tomorrow I will cry! :cry:
PostPosted: Sat Dec 26, 2009 2:33 pm
points frozen shut, condensor, plugs, cracked dizzy cap, dirty rotor arm ,dirty petrol, lead off the coil ,broken ht lead ,lead off the solenoid.... could be anything really ,id start by checking to see if you have a spark and go from there........
PostPosted: Sun Dec 27, 2009 3:01 pm
What Minis have you?: 60 Austin Se7en
61 van,68 MKII,
Check if you have spark first Stan and also check that the fuel pump is getting supply.
PostPosted: Sun Dec 27, 2009 3:11 pm
It has no spark as myself and a friend checked yesterday. I'v been told to replace the coil just and a process of elimination so I'm on the look out for one.
PostPosted: Sun Dec 27, 2009 5:13 pm
Get a multimeter, you can check the coil/leads etc with this. itl save you buying stuff you dont need.
PostPosted: Sun Dec 27, 2009 6:46 pm
Cheers Kona, I'l get one from one of th lads in the garage tomorrow. Mustard tryed a coil pack which came of BERTs clubman estate but still nothing. I'm starting to become afraid of the idea of a new ecu :shock:
PostPosted: Sun Dec 27, 2009 7:48 pm
correct me if im wrong but berts clubby is carbed stud is spi it wouldn't work anyway
PostPosted: Sun Dec 27, 2009 9:28 pm
SPI still has a distrbuter and coil! MPI has a different coil unit which cant be interchanged
PostPosted: Sun Dec 27, 2009 10:03 pm
as i said correct me if i'm wrong! learn somethin new everyday
PostPosted: Mon Dec 28, 2009 12:32 pm
:D
PostPosted: Mon Dec 28, 2009 3:46 pm
If its not the coil pack what do you think it is? As I said in the pm I have ignition spares if you need a loan
PostPosted: Mon Dec 28, 2009 6:38 pm
All thats left is the ECU or crank sensor
PostPosted: Mon Dec 28, 2009 7:34 pm
Don't say the ecu BERT! Please don't. I afraid to put the Mini on tow as I have no brakes because the pedel is solid as a rock! When you get your trailer back will you let me know BERT and I can just tow it with the Passat. And thanks again for the offer Briain
PostPosted: Mon Dec 28, 2009 7:44 pm
I have a spair know good spi ecu I use for testing if you need a lone give me a shout but I doubt it's your problam
regards
Paul
PostPosted: Mon Dec 28, 2009 8:08 pm
Cheers Paul, if I need it will shall give you a text.
PostPosted: Wed Dec 30, 2009 10:40 pm
Hi Stan
did u get the motor running yet
Number8
"Small car, but great history to it."
PostPosted: Thu Dec 31, 2009 4:32 pm
Not yet Number 8, something very satrange happened today though. Today was I had decent enough weather to go out and clean Stud so I did but as I was going to get him for the driveway of the house two doors down (There gone away) I put the keys in the ignition to unlock the steering lock and as the ignition lights came on I got a noise like an imobiliser? Any ideas? I have never heard this noise before and its not my radio as I took it out. The noise is coming from somewere around the clocks but I cannot pin point the location.
It would make sense that iStud won't start because of an imobiliser but why nine months later is it only starting to work now? :|
PostPosted: Thu Dec 31, 2009 6:25 pm
Yes some of the late SPIs it think from 94 on had Immobilize I guessed it might be your problem,
there simple enough to bypass when you turn the ignition on does the fuel pump run ?
Stick your head in the boot and get a mate to turn the key to the crank position.
PostPosted: Thu Dec 31, 2009 6:38 pm
What Minis have you?: 1971 Mini 1000, Yellow 1980 Super Deluxe, 1977 Mini Pick-up, 1980 Minivan, 2003 Vectra GTS Turbo Sport, 1993 Calibra, 2001 Transit Recovery Truck.
I had a 94 that immobillized spark and start relay but fuel pump still ran. Totally threw me off
http://www.castletownmotors.ie
PostPosted: Thu Dec 31, 2009 6:39 pm
It don't seem to make noise but the battery is close to flat so I don't know if that makes a difference. Rov had an immobiliser but I never seen one on a Jap import (which Stud is)
PostPosted: Thu Dec 31, 2009 6:56 pm
Get a charged battery or jump leads on him and then test and as Gareth says make sure you have a spark a simple test to see if it is just a fuel issue is take of the air cleaner and poor about 3 table spoons of raw petrol into the throttle boddy press the throttle and crank the motor if it starts then you know the ECU is Ok the spark is ok and all you need do is get fuel to it :)
PostPosted: Thu Dec 31, 2009 7:09 pm
Itr already been blased by easy tart and we gone nothing. And when it's being turned over we ain't getting a spark so it doesn't really matter if it's getting petrol at the moment because there is nothing to make it explode!
PostPosted: Mon Jan 04, 2010 1:09 pm
And a week later he lives again, it turned out to be a corroded relay which the little brother father by-passed and now he's running a beaut! :D
