It is currently Fri Nov 03, 2017 6:24 pm
 Post subject: Vented disc brakes
PostPosted: Mon Dec 28, 2009 6:47 pm
What Minis have you?: 60 Austin Se7en
61 van,68 MKII,
I was wondering if there is a need to go with vented discs on my GT or would it be overkill.I would be running 7.9" four pot calipers.It will have a 130bhp stove .
 Post subject: Re: Vented disc brakes
PostPosted: Mon Dec 28, 2009 7:08 pm
iv got some used vented discs from a metro, could be turned down on a lathe...
il swap ya for sumn of whatever i can salvage from that clubby estate you have if your interested??
some day....
PostPosted: Mon Dec 28, 2009 7:20 pm
I found that they are average when there cold but when u warm and get heat into them there very good, as hard as ever i went i did nt get any break fade, green stuff pads and braded hoses u could nt go wrong :D
PostPosted: Mon Dec 28, 2009 7:55 pm
No need Adain, some of the racers are on cross drilled 7.4 disks, I however would not recomend green stuf there complete rubish IMHO, DS2000 or mintex 1144.
Regards
Paul
PostPosted: Mon Dec 28, 2009 8:15 pm
Whats your location?: THE FRIDGE I TOLD YE!!
Modifications: no more custom flakey paint, now new custom crevice paintwork
i'd stay away from the green stuff too, i have them on mine and they take a while to heat up to effective temperature,
and then you have to keep them their,
i'll be getting Paul to fit either of the ones he's mentioned above soon :D
