It is currently Fri Nov 03, 2017 6:07 pm
Post new topic  Reply to topic  [ 12 posts ]
 Post subject: Throttle cable
PostPosted: Fri Oct 08, 2010 8:38 pm
Hi all, need to replace the throttle cable on the estate. Did I read here before that a bicycle brake cable will suffice? Is this a quick fix only, or will it do a permanent job?
MINI
...where size doesn't matter!
 Post subject: Re: Throttle cable
PostPosted: Fri Oct 08, 2010 9:37 pm
Whats your location?: THE FRIDGE I TOLD YE!!
Modifications: no more custom flakey paint, now new custom crevice paintwork
It would be a quick fix job but, some people have had them in their cars for years without any problems,
your choice really :wink:
PostPosted: Fri Oct 08, 2010 10:45 pm
What Minis have you?: 1971 Mini 1000, Yellow 1980 Super Deluxe, 1977 Mini Pick-up, 1980 Minivan, 2003 Vectra GTS Turbo Sport, 1993 Calibra, 2001 Transit Recovery Truck.
Once the outher cable is ok an you get the right connector on the end of the cable does the job just dandy... mine running fine with it anyway.
http://www.castletownmotors.ie
PostPosted: Sat Oct 09, 2010 12:15 am
:roll: see what i mean :D
PostPosted: Sat Oct 09, 2010 2:05 pm
I was using one with no major issues. The biggest problem was trying to get it fed through to the pedal from the engine bay. I was also worried about it melting so put a proper cable on it!
PostPosted: Sat Oct 09, 2010 2:36 pm
What Minis have you?: Mk3 100bhp all 70s spec
Mk2 998 cooper (coming soon)
86 coupe quattro
87 quattro
That must have been a struggle it supposed to go the way. IMHO a brake cable would take more abuse. Probably no difference in them at all.
Stewart
Lucas, the prince of darkness
PostPosted: Sat Oct 09, 2010 8:56 pm
Gear cable is alot thinner than Brake cable, they also have different ends.
Cant Imagine the steel cable melting either, Id imagine if it gets that hot the cable is the least of your worries :p
PostPosted: Sat Oct 09, 2010 8:59 pm
ive seen steel throttle and choke cable melt.. due to bad engine earth mind you, not exhaust heat.
PostPosted: Sun Oct 10, 2010 7:56 pm
Thanks for the replies folks. I intend putting this mini into regular use, just need to fill her with fresh oil and replace the kinked cable and we should be set.
MINI
PostPosted: Mon Oct 11, 2010 10:31 am
Hi Kev,
I have throttle cables in stock if you want to drop up to me during the week we can sort that oil change and fit you cable,
best regards,
Paul.
PostPosted: Mon Oct 11, 2010 8:47 pm
Thanks merlin, changed the oil today but not driving 100% due, I suspect to either a kinked cable and/or timing or carb adj. issues. It will be next week when I get up to you if thats ok. Ill bell ya friday.
MINI
PostPosted: Tue Oct 12, 2010 11:25 am
Good man Kev chat to ya then.
