It is currently Fri Nov 03, 2017 10:41 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Wed Nov 16, 2011 8:31 am
Whats your location?: wicklow
What Minis have you?: 1275 mayfair auto.
Modifications: stage 1 kit
hi guys is it easy to change rear passenger light unit and if i undo tank will it move far enough to get unit in easily or will i have to disconect tank as im not sure about doing that myself, any info would be grateful, thanks a mill :? :? :?
PostPosted: Wed Nov 16, 2011 12:27 pm
Whats your location?: THE FRIDGE I TOLD YE!!
Modifications: no more custom flakey paint, now new custom crevice paintwork
just undo the strap that holds the tank in place and wiggle it over out of the way from the bottom, the filler neck should come back in through the hole, you don't need to move it much though,
you should be able to reach the nuts then to undo the lamp
PostPosted: Wed Nov 16, 2011 12:33 pm
thanks macker ill have a go if this lovely weather goes away, cheers, by the way would it benefit me to silicone around the seal under rubber rather than using the sticky tape, thanks again
PostPosted: Wed Nov 16, 2011 1:43 pm
i wouldn't advise using silicone anywhere near a painted surface, especially on minis since they are prone to tin worm,
why were you going to use it or the tape anyway?
PostPosted: Wed Nov 16, 2011 6:21 pm
i had just got it back from workshop and the guy who sprayed it had taken out lights and had a sort of double sided foam tape inside the light unit itself but it let bthe water in so hence having to change it, i thought it needed to be there so was thinking silicone rather than the tape, its not touching body its the seal from the lens to unit, sorry bout the confusion, thanks again.
PostPosted: Wed Nov 16, 2011 7:07 pm
PROJECT X
you can buy replacement seals.
PostPosted: Wed Nov 16, 2011 7:18 pm
could i get them in any motorfactors or does it have to be a mini special or just a roll of that tape and cut to suit???
PostPosted: Thu Nov 17, 2011 10:16 am
PROJECT X
Somerford ship on the day if you order before noon, 3 days post to Ireland is about the norm.
http://www.somerfordmini.co.uk/eshop/in ... page&id=79
Or you could try Ian in MiniQuip up north, he is on here a fair bit
http://mini-quip.co.uk/
PostPosted: Fri Nov 18, 2011 9:01 am
thanks a mill for all the help guys and ill be onto ian for the seal asap, thanks tmg
